[DF] Debug & Developer mode - This simple addon will allow you to enable debug and/or development mode from within your ACP.
This simple addon will allow you to enable debug and/or development mode from within your ACP. This helps so you do not have to edit your config.php file.
There are four settings for the addon.
- Enable debug mode. You can enable/disable debug mode with this option.
- Enable development mode. You can enable/disable development mode with this option.
- Default addon. Set a default addon during addon development.
- Cron enabled. You can turn the cron job...
