LV - Question Threads Notify - The plugin adds a warning above the editor in topics with questions
The plugin adds a warning in topics with questions, which reminds you that if someone's answer turned out to be useful, then it should be highlighted as the right solution, and if the solution already exists, it will recommend removing it if it is irrelevant / incorrect. Only the author of the topic sees the warnings.
WITH SOLUTION:
WITHOUT SOLUTION:
WITH SOLUTION:
WITHOUT SOLUTION:
