OzzModz - Debug & Development Mode From ACP
Free OzzModz - Debug & Development Mode From ACP 2.0.0
OzzModz - Debug & Development Mode From ACP - Enable debug and/or development mode from within your ACP.
This simple addon will allow you to enable debug and/or development mode from within your ACP. This helps so you do not have to edit your config.php file.
There are four settings for the addon.
  • Enable debug mode. You can enable/disable debug mode with this option.
  • Enable development mode. You can enable/disable development mode with this option.
  • Default addon. Set a default addon during addon development.
  • Cron enabled. You can turn the cron job...
