OzzModz - DragonByte eCommerce Product Form Options
Free OzzModz - DragonByte eCommerce Product Form Options 2.0.0
OzzModz - DragonByte eCommerce Product Form Options - Customize the product add/edit form, remove unneeded fields, etc
This simple addon allows you to hide unnecessary fields on the product add/edit form in DragonByte eCommerce, along with set default starting values for things like weight, stock, and checking shipping zones.
The addon was developed for client usage and is now being made available as a niche-use product. For example, if your store is very simple and you tend to have the same type of product, you can configure the options to make adding products easier and without extra clutter.
However...
