SVG - Master Style Alert
Free SVG - Master Style Alert 1.1.1
SVG - Master Style Alert - Warning when editing Style Master or Language Master
Do you often exit design mode and then accidentally end up editing the master stylesheets in the templates section?
You don't need this plugin if you don't create or edit anything, don't know what developer mode is, and so on, don't download thoughtlessly.
This small addon will turn the style selector bright red when choosing the main style, warning you that you are currently time to edit the main style.
Install the add-on and it should be activated. There are no settings.
Design mode...
