This guide will allow you to have a single option group for all your options, separating them into tabbed sections rather than forcing users to change option groups.
EXAMPLE:
EXAMPLE:
Code Event Listener:
Event:
templater_macro_pre_render
Event Hint:
admin:option_macros:option_form_block
Execute Callback:
Your\Namespace\Listener :: templaterMacroPreRender
PHP Code:
PHP:
<?php
namespace Your\Namespace;
class Listener
public static function templaterMacroPreRender(\XF\Template\Templater $templater, &$type, &$template, &$name, array &$arguments, array &$globalVars)
if (!empty($arguments['group']) && $arguments['group']->group_id == 'your_group')
// Override template name
$template = 'your_namespace_option_macros';
// Or use 'option_form_block_tabs' for tabs
$name = 'option_form_block';
// Your block header configurations
$arguments['headers'] = [
'generalOptions' => [
'label' => \XF::phrase('general_options'),
'minDisplayOrder' => 0,
'maxDisplayOrder' => 2000,
'active' => true // Only used for tabs, indicates default active tab
'otherOptions' => [
'label' => \XF::phrase('other_options'),
'minDisplayOrder' => 2000,
'maxDisplayOrder' => 3000
'evenMoreOptions' => [
'label' => \XF::phrase('even_more_options'),
'minDisplayOrder' => 3000,
'maxDisplayOrder' => -1 // This allows for any higher display order value
Admin Template:
Template Name:
Template Contents:
HTML:
<xf:macro name="option_form_block" arg-group="" arg-options="!" arg-containerBeforeHtml="" arg-headers="{{ [] }}">
<xf:if is="$options is not empty">
<xf:form action="{{ link('options/update') }}" ajax="true" class="block">
{$containerBeforeHtml|raw}
<div class="block-container">
<xf:foreach loop="$headers" value="$header">
<xf:macro name="option_rows" arg-header="{$header.label}"
arg-group="{$group}" arg-options="{$options}"
arg-minDisplayOrder="{$header.minDisplayOrder}" arg-maxDisplayOrder="{$header.maxDisplayOrder}" />
</xf:foreach>
<xf:submitrow sticky="true" icon="save" />
</div>
</xf:form>
</xf:if>
</xf:macro>
<xf:macro name="option_form_block_tabs" arg-group="" arg-options="!" arg-containerBeforeHtml="" arg-headers="{{ [] }}">
<h2 class="block-tabHeader tabs" data-xf-init="tabs" role="tablist">
<xf:foreach loop="$headers" key="$key" value="$header">
<a class="tabs-tab{{ $header.active ? ' is-active' : '' }}" role="tab" tabindex="0" aria-controls="{$key}">{$header.label}</a>
</xf:foreach>
</h2>
<ul class="tabPanes">
<li class="{{ $header.active ? 'is-active' : '' }}" role="tabpanel" id="{$key}">
</li>
</xf:foreach>
</ul>
</div>
</xf:form>
</xf:if>
</xf:macro>
<xf:macro name="option_rows" arg-header="" arg-group="!" arg-options="!" arg-minDisplayOrder="{{ 0 }}" arg-maxDisplayOrder="!">
<xf:set var="$hundred" value="0" />
<xf:if is="$header">
<h3 class="block-formSectionHeader">{$header}</h3>
</xf:if>
<div class="block-body">
<xf:foreach loop="$options" value="$option">
<xf:if is="{$option.Relations.{$group.group_id}.display_order} >= $minDisplayOrder AND ({$option.Relations.{$group.group_id}.display_order} < $maxDisplayOrder OR $maxDisplayOrder == -1)">
<xf:if is="$group">
<xf:set var="$curHundred" value="{{ floor($option.Relations.{$group.group_id}.display_order / 100) }}" />
<xf:if is="{{ $curHundred > $hundred }}">
<xf:set var="$hundred" value="{$curHundred}" />
<hr class="formRowSep" />
</xf:if>
</xf:if>
<xf:macro template="option_macros" name="option_row"
arg-group="{$group}" arg-option="{$option}" />
</xf:if>
</xf:foreach>
</div>
</xf:macro>
There are two macros in this template. Change the configuration in the event listener as required.
- Replace all instances of
your_group
with the option group ID you used. - Replace all instances of
Your\Namespace
oryour_namespace
with the relevant namespace you use. - I chose to separate my options per 1000 display order, but you can edit the PHP code and do it however you like.
